Re: Unleaded gasoline for old tractors?
Posted by Bob Kerr on August 06, 2001 at 14:38:20 from (152.163.197.74):
In Reply to: Unleaded gasoline for old tractors? posted by Roger Nixon on August 06, 2001 at 12:52:58:
I am not exacty sure when lead was first used but I think it was around 1939 or so. It could have been after WW2.So a lot of tractors were built before lead even came out and are still running. Most tractors don't have the higher compression that lead was needed for. Lead also helped when the cam shafts had higher lifts and stronger valve springs to keep the cam lifters from floating at high speeds.Tractor engines are long stroke,High torque,low compression,low RPM engines and just don't need lead as a rule.
Post A Followup
: Re: Re: Unleaded gasoline for old tractors?
