Re: 300 block removal(darn, darn, darn)
Posted by the tractor vet on August 06, 2001 at 22:45:34 from (216.196.13.224):
In Reply to: 300 block removal(darn, darn, darn) posted by doug vose on August 06, 2001 at 19:25:15:
Well your heading in the wright direction , it would be a big help if you had a cherry picker and you need a good set of jack stands. Support it under the clutch houseing , hook the cherry picker to the ft. bolster and remove the left frame rail amd remove the bolster lay it down out of the road then hook the engine up and finish removeing the rest of the bolts. When reinstalling it DO NOT FORCE IT TOGETHER you have two sets of splines to get lined up in the clutch and ppa.
Post A Followup
: Re: Re: 300 block removal(darn, darn, darn)
