Re: 1066 fuel drain
Posted by the tractor vet on August 07, 2001 at 19:27:06 from (216.196.12.90):
In Reply to: 1066 fuel drain posted by R Rahmier on August 07, 2001 at 19:01:03:
It is used to drain off the bottom of the tank to get water and sediment out , More then likley you have a rusted out line that needs to be replaced . I have fixed three sofar this year. Hardly anybody ever drains there tank and the water gets in the littel line and rusts it out from the inside.
Post A Followup
: Re: Re: 1066 fuel drain
