Re: Radiator studs
Posted by Haas on August 08, 2001 at 07:46:34 from (129.37.117.10):
In Reply to: Radiator studs posted by Mike H. on August 07, 2001 at 20:57:20:
I had this problem on one of the studs that holds the rocker arm assembly on my C. The center stud is drilled for oil flow. I went to an auto parts store. They had all kinds of stud bolts and likely a NAPA store can get your radiator studs for you. I found the stud for the C, but had to drill the oil holes myself. I've found that IH often discontinues parts that are standard hardware items, like the stud bolts.
Post A Followup
: Re: Re: Radiator studs
