Re: Re: Rotary Mower Cutter For Farmall M
Posted by Redstick on August 08, 2001 at 09:21:33 from (216.93.56.155):
In Reply to: Re: Rotary Mower Cutter For Farmall M posted by Haas on August 08, 2001 at 07:52:44:
Hello Haas. I won't argue the valid point you made about the slip clutches vs shear bolts. I've just completed mowing 35 acres with a Woods 6' XT172 rotary cutter. The grass was so high in some spots that my H started to bog down so I finished with the 730 diesel. I didn't bust a single grade 2 shear bolt using a 60 hp tractor driving a 40 hp pto gearbox. This guy is looking for a nice, affordable, apparently light duty rotary cutter. I recommended a Woods cutter and relayed my experience. My neigbor was using a rotary cutter with a slip clutch (I can't recall the brand name) and he was too lazy to get off the tractor to investigate why his clutch was slipping. Turns out he had inadvertently sucked up some wire into the mower and it was binding up. The slip clutch overheated, melted the plastic clutch shield and ignited the brush clippings and residue on top of the mower deck. Cost him a gob of money to get the mower fixed, and nearly burned up his field. May not have happened with a shear bolt. I know that sometimes the shear bolt can be a pain but if I have to do that much heavy cutting, I'll use a mower that is big enough to do the job. The bigger mowers with heavier gearboxes use harder shear bolts and can subsequently withstand greater shocks when cutting heavier material. I don't have anything against slip clutches, but it's going to cost that much more for the mower. I certainly don't recommend using shear bolts with greater hardness grades than what's recommended by the manufacturer to avoid damaging the costly-to-replace gearbox or my tractors. In the end, you'll get what you pay for. It all depends on what you're going to cut with it and how you cut with it. Thanks for your input on your experience with mowers Haas. This guy will hopefully read these posts and come to an informed decision on what he needs for whatever mowing jobs he wants to do.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
