Re: Rotary Mower Cutter For Farmall M
Posted by sod on August 08, 2001 at 09:30:15 from (209.206.151.60):
In Reply to: Rotary Mower Cutter For Farmall M posted by Tom M on August 07, 2001 at 16:55:21:
I am very happy with the use of the "Southern"
brand rotary cutter. I bought a 6' medium duty for 1100 bucks. I use it behind the 450 farmall. I break shear bolts now and then. That's what is supposed to happen if you hit something tough.
The shear bolts on that is 1/2 inch bolts. The gearbox is rated for 65 horses.
good luck
sod
Post A Followup
: Re: Re: Rotary Mower Cutter For Farmall M
