Re: Oil leak on A
Posted by Farmer Bob on August 09, 2001 at 20:08:24 from (208.49.9.48):
In Reply to: Oil leak on A posted by Norman on August 09, 2001 at 19:58:46:
Norman, Good possibility that the oilpan flange is warped or otherwise out-of-shape or you may have overtightened the pan bolts. It doesn't take much to create a leaker. Recommend you remove the pan, get a new gasket and check the flange for trueness. I use a large piece of plate glass to check pans. take a $ bill and move it around between the flange and the glass. If it binds the pan is "high" at that point, if it slides out with no resistance you have a "low" spot. I use the red silicone gasket sealer and only tighten the bolts up to around 10 ft. lbs./FB
Post A Followup
: Re: Re: Oil leak on A
