Re: 300u fan belt
Posted by Bob M on August 10, 2001 at 07:21:37 from (165.170.128.65):
In Reply to: 300u fan belt posted by Randy on August 10, 2001 at 05:09:20:
Randy - The fan/water pump pulley is split, similar to the pulley on the generator. The front flange half of the pulley is threaded onto the hub and is locked in place with a set screw. Loosen the fan hub flange by backing the set screw out 8 - 10 turns, then use a hammer and punch working on the hub dogs to unscrew the front flange. A good dose of PB Blaster or similar lubricant on the hub threads first is helpful...
You should be able to thread the new gen belt on without completely removing the fan belt. After loosening the fan pulley, work the fan belt off the crank pulley. Then lift it out of the fan pulley groove and let it hang on the fan hub. Now work the new gen belt over the fan blades, under the loosened fan belt and back into it's groove on the fan hub. Finally remount and tighten the fan belt. ...Bob M
Post A Followup
: Re: Re: 300u fan belt
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
