Re: How Do YOU Get The A's Adjustable Front Axle To Come Out??!!
Posted by Andy Martin on August 10, 2001 at 18:30:46 from (63.27.17.179):
In Reply to: How Do YOU Get The A's Adjustable Front Axle To Come Out??!! posted by ThatOtherGuy on August 10, 2001 at 14:34:02:
Use penetrating oil. A little every day. It might take a few weeks. It will soak in. You can use a curved block of wood on the inside of the kingpin tube to drive against with a hammer, but be careful not to dent the tube. Time and penetrating oil is the best way. Eventually you can twist the axle tube and work it out.
Post A Followup
: Re: Re: How Do YOU Get The A's Adjustable Front Axle To Come Out??!!
