water in oil
Posted by gregy on March 15, 2009 at 13:45:54 from (71.215.9.174):
The lube oil in the trans, rearend of my utility 350 is grayish yellow. Where could the water be coming from. Radiator level is full, crank case oil is black. The yellowish color makes me think there is antifreeze in it. Is there anywhere where they share a common seal? Thanks.
