Re: Where's the engine number on an AOS6 or W6 McCormick Inter tractor
Posted by Will@ont.ca on August 11, 2001 at 21:43:28 from (216.58.67.71):
In Reply to: Where's the engine number on an AOS6 or W6 McCormick Inter tractor posted by David on August 11, 2001 at 00:00:18:
David,Below #1 spark plug there,s a flat piece of cast if you sand off the rust or grease- dirt you will see the serial #.Unless the motor has been changed the # will apply to the whole tractor Will
Post A Followup
: Re: Re: Where's the engine number on an AOS6 or W6 McCormick Inter tractor
