Re: What is the diff between a B and BN?
Posted by Phil Auten (Tx) on August 13, 2001 at 08:51:34 from (63.173.243.98):
In Reply to: What is the diff between a B and BN? posted by Danny Y on August 13, 2001 at 06:53:50:
Danny,
The B and BN were produced concurrently from 1940 through 1948.
The difference in the BN is that the rear axles and housings are 4" shorter on each side, making the rear tread 8" narrower than a B. The B rear tread was variable from 64-92 inches and the BN was variable from 56-84 inches.
Phil
Post A Followup
: Re: Re: What is the diff between a B and BN?
