Re: How to Add HP to M
Posted by john d on August 13, 2001 at 14:38:08 from (205.188.197.184):
In Reply to: How to Add HP to M posted by John on August 13, 2001 at 12:54:17:
To farm with, or pull with?? If you're going to play the tractor-pulling game, get ready to spend major $$$ and get some advice from those on the pulling board. If the goal is to transform it into a Red Beast for field work, you're taking the major step with the oversize sleeves and pistons. IH Firecrater pistons and sleeves alone will push the power to about 45-48 hp. I think there is an ignition advance upgrade kit available for use with those internal parts. Piston sets are generally available in different compression ranges for different altitude situations. Putting in the higher compression pistons will gain some more power, but you'd better listen carefully for any pre-ignition knocking when it's under load, and be ready to back the ignition timing off a little. A good machine shop can tweak the head a little to make it breathe better, and an aftermarket governor kit will let it respond to a load almost instantly. After you've sorted all this out, consider opening up the governor and let it run faster than stock. Up to the point where an engine can't breathe efficiently, more rpms generally result in more hp. I've got an old '49 M that has the M&W overbore kit, an improved governor, and the rpm limit set at about 2000. A few years ago, it showed 52 hp on the dyno.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
