Re: changing WF pivot pin
Posted by George 2 on August 15, 2001 at 18:39:55 from (216.46.140.186):
In Reply to: changing WF pivot pin posted by GSS on August 14, 2001 at 14:23:02:
Been there, done that. The bushings will have to be changed and the pivot pin probably will too. I did this job on my 560 a few years ago and there is one hitch. While the bushings are easy to press in, the bushings are not machined to fit. You will have to use a hone with your electric drill to hone them out so you can pass the pivot pin through the bushings. It is a pain do do it with the axle still on the tractor(radius rod still hooked up)and do a good quality job). The hones tend to wear unevenly and you have to move them around a lot to ensure you get the correct diameter on the bushing.
Post A Followup
: Re: Re: changing WF pivot pin
