Re: 656 shifting problem
Posted by kev@ia on August 15, 2001 at 18:46:22 from (206.72.15.209):
In Reply to: 656 shifting problem posted by Mark on August 15, 2001 at 06:01:54:
Hello Mark, I know what your talking about, dads 544 uses the same shift setup. I made a new shifter shaft and built up some worn areas so that most of the shifting woes were curred back in Dec or Jan. The Quick fix that will help is to remove the casting that holds down the springs on top of the trany and put a short 1/4 bolt with the threaded portion in the spring and the head against the ball so it is under more preasure. Also make a bigger hole in the shaft that runs through the links so that the ball bearing can make nuteral more evident. Get a over length die makers dowl pin and grind to length as it will bear on unworn metal and remove a lot of slop. The factory pin is to short and wears to fast. Check the archives as I posted about this before. Good luck and if you need more help just post for it. kev
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
