Re: Re: 1941 M going dead
Posted by SupC on August 15, 2001 at 20:43:25 from (64.7.225.5):
In Reply to: Re: 1941 M going dead posted by Bill Smith on August 15, 2001 at 20:33:53:
I had a 240 that did the same thing, when I bought it they said it had always ran better with a full tank, and after it got low it would die. The problem was over the years water in fuel had ate off the stem of sediment bowl assy. that sticks up above the bottom of the inside of fuel tank. This put it sucking off the bottom of the tank, and it had pulled rust, bugs, etc. just down inside the inlet of the sediment housing and slowed the flow. That may not be the problem, but it sure sounds like a gas restriction problem somewhere.
Post A Followup
: Re: Re: Re: 1941 M going dead
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
