Re: Adding hydaulics to a B
Posted by Haas on August 16, 2001 at 18:40:10 from (129.37.117.238):
In Reply to: Adding hydaulics to a B posted by Will on August 16, 2001 at 08:40:29:
Saw a B a while back with hydraulics and a wide front. It was done with parts from a Super A and some modifications of the wide front. I guess they used the engine block from the Super A, as the hydraulic pump was in the block and the B has no place for it. Also, I think you could take the engine and hydraulics out of a C and stick it in there to get hydraulics if you want to keep the tricycle front that the B has. You have to keep the front from the B, because the steering gear is on the opposite side on the C. Also the same thing would work with a Super A engine and hydraulics.
Post A Followup
: Re: Re: Adding hydaulics to a B
