Re: Re: 400D RUNS MANY THANKS!!!!!!!!!!!!!!!
Posted by Roger on August 17, 2001 at 19:51:06 from (209.224.20.102):
In Reply to: Re: 400D RUNS MANY THANKS!!!!!!!!!!!!!!! posted by Farmall43 on August 17, 2001 at 10:41:17:
If you do as Haas says and shut off the gas, it will only run for about 30 seconds before it stops in gasoline mode (at least that is the way my MD does). Two minutes is a long time to let it run in gasoline mode. Usually dieseling after shutting off a gasoline engine is due to carbon buildup in the cylinders which is glowing hot and ignites the fuel like a spark plug. So if you shut off the fuel as Haas says, there will be no fuel to burn and you shouldn't have dieseling. Roger
Post A Followup
: Re: Re: Re: 400D RUNS MANY THANKS!!!!!!!!!!!!!!!
