Re: 51 M Has a Knock
Posted by Ed H. on August 17, 2001 at 21:01:10 from (216.93.25.61):
In Reply to: 51 M Has a Knock posted by joe on August 16, 2001 at 19:12:40:
WITH THE MOTOR RUNNING, PULL ONE SPARK PLUG WIRE AT A TIME , TO ISULATE THE KNOCK..THEN YOU KNOW WHAT CYL. TO CHECK. IF YOU PULL THE PAN AGAIN, TAKE THE ROD CAP OFF , AND PUSH THE PISTON UP JUST TO CLEAR THE CRANK(BE CAREFULL,TOO FAR , AND A RING MIGHT POP OUT OF THE BORE)..NOW CHECK TO SEE IF THE TOP END OF THE ROD WILL MOVE BACK AND FORTH ON THE PISTON PIN, IT SHOULD SLIDE SMOOTHLY.....IF THE ROD IS STICKING ON THE PIN , THE PISTON WILL KNOCK ON ACCELERATION...WHAT YOU'LL HEAR IS THE PISTON SKIT , SLAPPING THE BORE...ON SOME RODS(SMALL END)THERE IS A LUBRICATING HOLE ,DRILLED IN THE TOP, AND THIS IS THE ONLY WAY IT GET OIL....ALSO ON AN ENGINE THAT SITS AWHILE , THE PINS TEND TO SIEZE UP IN THE PISTONS
Home
| Forums
Today's Featured Article -
Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
