Re: Super A Govenor
Posted by Mark on August 18, 2001 at 05:27:11 from (64.12.103.157):
In Reply to: Super A Govenor posted by Tbrake on August 17, 2001 at 20:39:55:
I just had the same problem with my Super C. I replaced the shaft because it was badly worn then discovered the housing was also worn. The housing is at the machine shop right now having a bushing installed. I'll let you know how it works.
Mark
Post A Followup
: Re: Re: Super A Govenor
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
