Re: Re: Farmall M 27,676
Posted by Andy Martin on August 18, 2001 at 18:32:49 from (63.26.134.58):
In Reply to: Re: Farmall M 27,676 posted by Bob in Southwest Iowa on August 18, 2001 at 14:32:06:
I bet the water in the transmission is more likely in H's because M's are more likely to have been cared for better under working conditions where the H's were relegated sooner to raking hay and pulling trailers where it is easy to forget to do any maintenance.
I think the major source of water is condensation. Every morning the transmission expels cool dehumidified air, and in the evening it sucks in warm moist air. It can really build up over time. When you pull the plug and all you get is crystal clear water I believe it is condensation (and no harm has been done). I always drain off the water in one that has been sitting before moving it just to avoid stirring the water. Most old M's I have looked at that have been sitting seem to have it, and some I have left sitting around have developed it.
One source of rainwater water is around broken top cover bolts. And broken top cover gaskets.
I can't see how rainwater can get in the shifter past the steel boot as long as the soft plugs are in place.
Post A Followup
: Re: Re: Re: Farmall M 27,676
