Re: Re: Farmall Super A tie rod adjustment...
Posted by James on August 19, 2001 at 11:55:46 from (24.159.57.171):
In Reply to: Re: Farmall Super A tie rod adjustment... posted by Andy Martin on August 19, 2001 at 11:36:34:
Andy, thanks for the response. My tie rods do have the clamps on each end like you mentioned. I think the "non-threaded" rod is too corroded to slide out of the sleeve. There are notches for the clamp bolt also. The thought did cross my mind about cutting the rod and welding an extension in the middle. I'm not convinced this is the solution at the moment. I am not in a hurry to start cutting just yet. If I can find a strong penetrant other than WD-40, I may try and soak it for a while. Again, thanks for your advice!
James
Post A Followup
: Re: Re: Re: Farmall Super A tie rod adjustment...
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
