Re: 12 volt conv. Alternator fit?
Posted by wh on August 20, 2001 at 05:46:26 from (216.180.38.52):
In Reply to: 12 volt conv. Alternator fit? posted by Gary on August 19, 2001 at 07:43:48:
have converted several "H"s. One of the best upgrades you can do. Just drop below your bracket and install an idler pulley. This will let you adjust your belt. I use a lawnmower pulley most of the time. Have one like this with close to 750 - 800 hrs on it with no problem. If interested can post pictures. WH
Post A Followup
: Re: Re: 12 volt conv. Alternator fit?
