Re: Oh Man! Something just happened to the H!?!
Posted by Andy Martin on August 20, 2001 at 09:32:00 from (63.25.216.3):
In Reply to: Oh Man! Something just happened to the H!?! posted by 1PWRFULH on August 20, 2001 at 09:17:53:
After you put fluid in, pull the brake covers. It sounds like you may have had a brake come loose and is dragging.
Empty to full is 6 gallons of gear grease, but you'll probably show full before you get 5 gallons in. I'd use 90w.
It will be all right even if you get to change out some bearings and gears.
If you like, pull off the belt pulley or blanking plate and see what the gears look like. If they are blue and chewed up, all right will take a little money.
Post A Followup
: Re: Re: Oh Man! Something just happened to the H!?!
