Re: Re: 1947 model b
Posted by Chuck on August 20, 2001 at 11:31:48 from (65.26.69.116):
In Reply to: Re: 1947 model b posted by Red Dave on August 17, 2001 at 18:11:21:
The single front wheel is typical of tractors produced to be used in irrigated fields. Tricycle fronts were too wide to run in the water furrow. So the single tire was the solution.
Post A Followup
: Re: Re: Re: 1947 model b
