Re: Re: Re: Re: Overrunning clutch part 2
Posted by Farmalittle on August 21, 2001 at 10:15:19 from (209.131.232.138):
In Reply to: Re: Re: Re: Overrunning clutch part 2 posted by wh on August 21, 2001 at 09:26:34:
My over running clutch has two grease fittings where the pin goes. You unscrew one of the fittings and place the pin in the empty hole. Then you screw the fitting back on. This prevents you from 1) not getting the pin in far enough, and 2)prevents the pin from working loose.
Post A Followup
: Re: Re: Re: Re: Re: Overrunning clutch part 2
