Re: Re: 22-36 Manifold
Posted by BJ on August 21, 2001 at 18:20:54 from (209.40.135.103):
In Reply to: Re: 22-36 Manifold posted by Farmall Paul on August 21, 2001 at 07:52:43:
The engine is stuck presently. I expect when I get the head off, it will be easy enough to free. The trans. will turn as I pulled 1 mile to my barn. My main problem is it missing the water pump and fan assembly. It is on cut-off wheels dating from 1939. I would like to put it on steel if I can find a set. I just finished a 1927 Farmall Regular, but it was running when I started.
Post A Followup
: Re: Re: Re: 22-36 Manifold
