Farmall Tractors Discussion Board
Re: tri cycle front end
Posted by Harold H on February 28, 1999 at 16:09:35:
In Reply to: tri cycle front end posted by joe on February 27, 1999 at 13:06:37:
Joe,
If you have a new axle to press in, make sure you have it turned the right way when you line up the rivet hole so the tractor will track. If you put it in backwards you will not be able to keep the tractor straight ahead.
Harold H
Post a Followup
: Re: Re: tri cycle front end
