Re: electrical problems with a farmall cub.
Posted by Farmer Bob on August 21, 2001 at 21:37:19 from (208.49.9.77):
In Reply to: electrical problems with a farmall cub. posted by Eric on August 21, 2001 at 19:09:53:
Eric, After using Bill's recommendation below, look at your "kill" switch and see how many contacts it has. The mag switch should only have one contact on it with the wire connected to it and running to the hookup point on the mag as you described. Someone may have slipped in a "two contact" switch meant for a distributer system. Also make sure that the switch is well grounded against metal and not all rusted up or corroded.//FB
Post A Followup
: Re: Re: electrical problems with a farmall cub.
