Re: Re: leaking oil pan gasket on super A
Posted by Andy Martin on August 22, 2001 at 09:23:40 from (63.27.16.47):
In Reply to: Re: leaking oil pan gasket on super A posted by Farmer Bob on August 21, 2001 at 21:31:19:
Getting the pan gasket surface clean straight cannot be overemphasized. Use a power wire brush to gently remove old gasket material if necessary. You can use a steel hammer if you don't have a brass one. Gently drive protruding areas around bolt holes back with the ball of a ball peen hammer. Use a large flat surface such as you coffee table to make sure the pan is not twisted or warped. A little time with a hammer and you can get the gasket surface very flat. I have a flat steel table I work them on. It is amazing how easily a good gasket surface will seal. If you use Form-a-gasket, READ THE INSTRUCTIONS. I am always surprised how a 1/16 to 1/8 inch bead can be interpreted by the user to mean two 1/4 or 3/8 inch beads. If you use the right amount you get very little or no squeeze out. Nobody will notice you used it. I used to make all my gaskets out of paper grocery sacks (work well on water pumps, etc.) or gasket material. Started using the polymer goop a while back and was pleasantly surprised by how well it works if installed correctly. Had a head outlet to thermostat housing on an M that was a chronic leaker (corroded both sides) and it sealed like a champ with VERY LITTLE sealant. If you see it squeeze out you put in too much.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
