Super C teardown
Posted by Farmer Bob on August 22, 2001 at 23:50:09 from (208.49.9.112):
Decided to pull the engine down on my SC tonight and found #1 and #3 piston oil scrapers mostly plugged with a rusty sludge. #1 being the worst and had a build up of rust up inside the piston skirt as well. Sleeves were in very good shape with only light surface blemishes and a minimal top "groove". Have not had any water in the oil or oil in the radiator. Tractor sat for at least 5 years without running and was not stuck. I've had it running about an hour before this teardown. Oil pressure gauge was broken and pick up screen was relatively clean. I plan on having the head done at a machine shop and will have them flux it just in case.
Will be replacing the bearings (rod and mains) and rings during the rebuild.
Any ideas on where this rusty stuff is coming from?//FB
Post A Followup
: Re: Super C teardown
