Re: M -not firing
Posted by The Red on August 24, 2001 at 05:51:13 from (12.84.238.27):
In Reply to: M -not firing posted by Scott on August 23, 2001 at 17:42:31:
Scott swap plug wires and see if the problem goes to the other cylinder. It it does then the plug wire is bad. If not, then you have a compression problem as Bigdog mentioned. It may be as simple as adjusting the valve lash. I set them .018 cold. If setting the valve lash doesn't help, then you have a burnt valve, valve seat or a combination of the two.
Post A Followup
: Re: Re: M -not firing
