Re: 1947 M Carb help
Posted by Bama Binder on August 24, 2001 at 06:48:42 from (206.5.110.200):
In Reply to: 1947 M Carb help posted by Alabama on August 24, 2001 at 06:16:06:
I don't know...black smoke is bad news..why don't you let me take it off your hands for say $600 or so...I wouldn't want you to have to worry about the carb problems.
Just kidding...some people have all the luck.
I think the procedure is to get it up to operating temp. Then screw in the needle that adjusts the main jet until RPMs pick up and then begin to fall off. Back it out to where the RPMs pick up again and than add 1/2 turn to make sure you are not running too lean. That should take care of the plack smoke.
If not, the needle valve may need to be replaced. If it were mine, I'd go ahead and spring for the Carb kit and rebuild it...you are so far ahead already I think you could afford the extra $$$s.
Good find!! BB
Post A Followup
: Re: Re: 1947 M Carb help
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
