Re: B starter question
Posted by big fred on August 24, 2001 at 20:43:25 from (208.51.245.59):
In Reply to: B starter question posted by Dave T on August 24, 2001 at 19:42:00:
I would agree with Phlogiston, you either have some rust in the bendix that is making it bind or you have a dirty connection or bad or undersize cable. All connections have to be clean for 6 volts to work well, even the mating surfaces where the starter bolts to the clutch housing. If you don't have a generator, you might find that a 12V battery will last longer between charges. My '41 B is electric start, no generator, and I could only get a few starts with 6 volts, with 12 volts I get dozens of starts and can leave the battery in the tractor over the winter and start it in the spring. Of course our temps rarely get much below freezing.
Post A Followup
: Re: Re: B starter question
