Re: wiring on a super a
Posted by peterc on August 25, 2001 at 18:49:45 from (64.30.154.79):
In Reply to: wiring on a super a posted by scott on August 25, 2001 at 12:15:42:
no need to rewire just change all the bulbs to 12 volt ,change coil and battery to 12 volt and install single wire alternator with internal regulator. hook battery negative to ground,battery positive to starter and swap wires on the ampmeter so it will read correctly. remove the old regulator and hook wire from bat connection on old regulator to the post on the alternator,other wires from old reg are eliminated.
Post A Followup
: Re: Re: wiring on a super a
