Re: M - MAIN BEARING PART NUMBER QUESTION
Posted by The Red on August 26, 2001 at 05:12:33 from (12.84.239.87):
In Reply to: M - MAIN BEARING PART NUMBER QUESTION posted by Joe on August 25, 2001 at 21:08:06:
I think you found the problem. For engine serial numbers 501-278049, use 45628DAX serial number for both halves standard size.
For engine serial number 278050 and later use 356985R11 for both halves, standard size.
I am guessing your serial number is between 501-278049. Sounds like someone didn't take the time to push out the upper bearing. It is probably well worn which would explain the knocking.
I am not sure what the L200 stands for though.
Post A Followup
: Re: Re: M - MAIN BEARING PART NUMBER QUESTION
