Re: Will 6 volt generator work on 12v
Posted by Burl on August 27, 2001 at 05:55:22 from (199.211.158.113):
In Reply to: Will 6 volt generator work on 12v posted by Michael on August 26, 2001 at 11:08:39:
My (gasp) JD B has a 6v generator with a 12 v regulator on it, and it works just fine. My Farmall 240 has the same setup, and works fine also.
Post A Followup
: Re: Re: Will 6 volt generator work on 12v
