Re: mccormik 10-20 pistons
Posted by spiffy1 on March 15, 2009 at 15:24:01 from (70.41.137.72):
In Reply to: mccormik 10-20 pistons posted by LenNH on March 14, 2009 at 18:24:05:
F-Dean said: (quoted from post at 06:49:44 03/15/09) How tight do you set yours using plasti-guage?
.003" However, there is a good chance a little out of round on the crank will make it more like .002 at the tightest point and maybe .005 at the loosest. The shims are .002 (so you can adjust roughly to the .001th by 1 less in one side, but in reality that's splitting hairs for the low RPMs and large bearing area with these) and if you have one layer more than just where it would bind at it's tightest point (assuming it's not tight all around or bind at all after adding a layer), you should be good to go.
