Re: H Hydrolic Pump
Posted by Chums5 on August 27, 2001 at 19:43:48 from (209.240.220.159):
In Reply to: H Hydrolic Pump posted by Don on August 27, 2001 at 18:31:08:
DON.....first uscrew the hyd. pipes(for quick disconnects) on both sides(IH welded together)they'll come out in one piece....next remove lever assy on r/h side and fill pipe....next under tractor the drive coupler...remove cotter pins and pipe sleeves slids to center and coupler should drop out.....next put a floor jack under pump and remove 4--3/8" bolts and slowly lower out of tractor.....DONE....to install reverse procedure.....Good Luck...
Post A Followup
: Re: Re: H Hydrolic Pump
