Farmall Tractors Discussion Board
Re: FRONT MAIN SEAL
Posted by Jim Smith Ft wayne on March 01, 1999 at 08:14:28:
In Reply to: FRONT MAIN SEAL posted by WD on February 27, 1999 at 12:05:54:
I made a puller/pusher to put the pulley back on. Heated the pulley up but not to much to melt new seal I just installed. Worked good. Just used threaded rod and a couple round plates of steel.
1/2 " rod. Big wrench, a few washers and 3 nuts, big plate of steel with small 1/2" hole in center.
Screw the threaded rod in as far as it will go into crank shaft. Double nut the end to keep the threaded rod from turning. Then tighten the third nut to push pulley back on.Presto
Jim
Post a Followup
: Re: Re: FRONT MAIN SEAL
