Re: IH Danco mower deck
Posted by Haas on August 29, 2001 at 05:28:58 from (129.37.117.70):
In Reply to: IH Danco mower deck posted by Daniel on August 28, 2001 at 10:53:41:
If the mower throws the grass to the left (that is blades turn counterclockwise), then more than likely the blade bolt threads are left hand. If it throws to the right, then the blade bolts will be righthand thread. I'm not familiar with the Danco mower, but this is the normal situation for blade bolts. If you rounded the heads and are using 12 point sockets or box ends, then go get a 6 point socket. Sometimes the 6 point socket will hold when the 12 point or other wrenches will not.
Post A Followup
: Re: Re: IH Danco mower deck
