Re: Tin work on Super M
Posted by Farmer Bob on August 29, 2001 at 08:26:33 from (208.49.9.49):
In Reply to: Tin work on Super M posted by Bill Sires, Jr. on August 29, 2001 at 06:26:08:
Bill, Check the adjustment on the radiator support rod that runs above the engine from the back of the upper radiator support bact to the gauge support post. If that rod adjustment is out of whack, you'll experience the wide gap in the hood to grille mesh. You can shorten the rod adjustment to close the gap.//FB
Post A Followup
: Re: Re: Tin work on Super M
