Re: Super A Farmall with Square Front Axle
Posted by Kendall on August 29, 2001 at 15:45:07 from (207.136.50.252):
In Reply to: Super A Farmall with Square Front Axle posted by Steve Ferguson on August 29, 2001 at 15:02:54:
The International Super-A had square front axel. Serial Number is on a plate under the seat on the left side support. Check serial number page on the left here under research and info. They are in the same run as Farmall Super-A's. Does your tractor have a foot operated gas pedal? This was a feature of the International. This tractor was made for non farm use, such as highway dept. mowing for example. Not to say you cant farm with it though.
Post A Followup
: Re: Re: Super A Farmall with Square Front Axle
