Re: radiator shutters???What do you think?
Posted by gene b on August 29, 2001 at 19:46:59 from (63.25.166.59):
In Reply to: radiator shutters???What do you think? posted by Bill Smith on August 28, 2001 at 21:34:08:
our new 49M came with shutters were fine in winter as we ground feed almost ever other day when we got a 24mounted picker in 51 took them off for better air flow went back to the gunny sack in winter to warm it up also made heat-houser work better
Post A Followup
: Re: Re: radiator shutters???What do you think?
