Re: Nuisance gas leak on Farmall B
Posted by redhead on August 30, 2001 at 08:17:07 from (63.62.138.110):
In Reply to: Nuisance gas leak on Farmall B posted by Dave T on August 29, 2001 at 21:45:18:
NAPA sells a sealer called REDKOTE. It's good stuff and easy to use.
Sounds like your B is leaking in the same spot my A was. There was crack where the baffle is spot welded to the inside of the tank. This spot weld is right under the mounting bracket. I ground the bracket back with a die grinder to expose the crack then brazed up the crack and put a new metal piece on the bracket. CAUTION: wash out the tank with hot/soapy water and let it dry in the sun for a few days with the cap and bowl off. Also, fill it with water before you grind and braze. Good luck.
Post A Followup
: Re: Re: Nuisance gas leak on Farmall B
