Re: w-6 timing?
Posted by Sven on August 30, 2001 at 15:12:04 from (207.230.238.66):
In Reply to: w-6 timing? posted by dan on August 30, 2001 at 14:18:20:
These tractors are fairly simple to time, first crank the engine by hand with your finger over the #1 cylinder hole (plug out)when you feel compression keep cranking until pointer on engine block lines up with mark on pully wheel. This is TDC. At this point the mag may or not have made a click noise (impulse trip). If it hasn't clicked yet your retarded and you can turn the mag until it does. If it has tripped then your advanced, so turn mag to retard timing (remember firing order is 1342 so rotate mag accordingly). Then crank engine by hand again and adjust mag until the impluse trips when pointer points to notch in wheel. Some wheels have alot of notches, on mine its the second notch of the 2 close together. It helps if you put some white paint on the notch. The last thing is, if you cant turn the mag enough so that impluse trips at TDC then move the rotor gear one tooth forward/back until it does. Hope this helps. Maybe someone else could explain it better or add to this. Remember to set mag points to.018" gap.Good luck.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
