Re: w-6 timing?
Posted by Sven on August 30, 2001 at 18:58:31 from (205.200.48.178):
In Reply to: w-6 timing? posted by dan on August 30, 2001 at 14:18:20:
I just wanted to add a few things I may have missed, if you have a magneto that uses the geared rotor, then you have to make sure that it is pointing to #1 cly terminal when piston 1 is at TDC. Remember that rotor turns from 2 to 1 (firing order 1342,1342).Rotate the rotor on the gear til you get it lined up. Then play with rotaing the whole mag body for retard/advance.
Post A Followup
: Re: Re: w-6 timing?
