Re: magneto conversion
Posted by 2ulew on August 30, 2001 at 21:39:21 from (206.58.190.145):
In Reply to: magneto conversion posted by Super A Wayne on August 30, 2001 at 12:56:03:
Wayne, The conversion that you are interested is a very simple procedure and I have done it many times with good results. Run the hot wire from the battery through a switch to the + terminal on the external coil. Run another wire from the - terminal on coil to what was the ground or kill post on the side of the magneto. Run your hi tension lead from the coil to the distributor type cap on the magneto and the spark plugs as they normally run. You can leave the internal coil in place or remove it as you wish but you will use the condenser as is. Questions or problems, email me. Good luck Lew
Post A Followup
: Re: Re: magneto conversion
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
