Re: built super c
Posted by gene b on August 31, 2001 at 03:45:22 from (63.42.174.173):
In Reply to: built super c posted by pete on August 30, 2001 at 18:50:20:
check with dennys carbs have heard of a cam for 240 helps is your head a high compression where the spark plug goes there is thicker caasting in the combustion area and then aslo across from there is thicker the conformatic pistons have a high dome that goes right up in this area the one I done had 140 lbs compression when done would not start with a mag statrts great with a dist you can also change jets and get a larger venturi for the carb have fun will be a nice running C could end up with 30hp real easy
Post A Followup
: Re: Re: built super c
