Re: sediment bowl
Posted by Farmer Bob on August 31, 2001 at 20:21:55 from (208.49.9.21):
In Reply to: sediment bowl posted by Dale on August 31, 2001 at 18:41:52:
Dale, I've had the same problem and cured it by filling the bowl about 3/4 full of gas and then tighten it up in place. Open the shut off valve and if the bowl doesn't fill the rest of the way up loosen it slightly until it does. Then tighten the bowl tension nut up. There is a vacuum problem sometimes with the air getting trapped in between the gas in the tank and the gas line to the carb.//FB
Post A Followup
: Re: Re: sediment bowl
